Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
First remove back cover, battery, chip and memory card .
Press these four latches (each side has two) to open front cover.
Carefully remove the bottom cover. This cover has no screws, only latches.
Front cover, rubber keyboard and bottom cover removed.
Remove these two Torx T6 screws at top of the smartphone.
Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
Carefully open the LCD and keyboard assembly, and remove keyboard connector.
Both sides of the LCD and keyboard assembly removed.
33 andere personen hebben deze handleiding voltooid.
4 opmerkingen
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Very clear tutorial !
The pictures are well lit, and the instructions are good :)
Thanks !
