Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
  1. First remove back cover, battery, chip and memory card .
    • First remove back cover, battery, chip and memory card .
  2. Remove 4 Torx T5 screws. Remove 4 Torx T5 screws.
    • Remove 4 Torx T5 screws.
  3. Press these four latches (each side has two) to open front cover. Press these four latches (each side has two) to open front cover.
    • Press these four latches (each side has two) to open front cover.
  4. Carefully remove the front cover with blade tool.
    • Carefully remove the front cover with blade tool.
  5. Carefully remove the bottom cover. This cover has no screws, only latches. Carefully remove the bottom cover. This cover has no screws, only latches.
    • Carefully remove the bottom cover. This cover has no screws, only latches.
  6. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  7. Front cover, rubber keyboard and bottom cover removed.
    • Front cover, rubber keyboard and bottom cover removed.
  8. Remove these two Torx T6 screws at top of the smartphone. Remove these two Torx T6 screws at top of the smartphone.
    • Remove these two Torx T6 screws at top of the smartphone.
  9. Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
    • Carefully remove the assembly. Dont forget to move away the plastic clip holding the assembly down. You can find this in the center on the bottom.
  10. Base assembly with small connectors and parts.
    • Base assembly with small connectors and parts.
  11. Remove the LCD connector.
    • Remove the LCD connector.
  12. Carefully open the LCD and keyboard assembly, and remove keyboard connector.
    • Carefully open the LCD and keyboard assembly, and remove keyboard connector.
  13. Both sides of the LCD and keyboard assembly removed. Both sides of the LCD and keyboard assembly removed.
    • Both sides of the LCD and keyboard assembly removed.
  14. I think that two small blocks are the gps antenna.
    • I think that two small blocks are the gps antenna.
  15. Both sides of battery - for reference only. Both sides of battery - for reference only.
    • Both sides of battery - for reference only.
Conclusie
28 andere personen hebben deze handleiding voltooid.
Jose Gustavo Abreu Murta
2.800 Reputatie
7 handleidingen geschreven
does anyone know if e71 have any battery on board? time and date keep resetting with battery removed.
cyfcyf - Antwoord
Yes there is, under the keypad, 3/4 of the way down the left side of looking from the front. It is soldered on to the board so take good care.
Samuel Wyatt -
Hi
I have this phone, but I can not charge it ,Because it has short in board ,plus it very short charger soket (female ), i’m use now extirnal charger only
what can i do ?
Dev Abokhadra - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 33
Altijd: 31,714
