Ga door naar hoofdinhoud
Disassembling Nokia E61i Microphone
Wat je nodig hebt
  1. Disassembling Nokia E61i Microphone, Battery: stap 1, afbeelding 1 van 2 Disassembling Nokia E61i Microphone, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Disassembling Nokia E61i Microphone: stap 2, afbeelding 1 van 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Microphone: stap 3, afbeelding 1 van 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Microphone, Front Cover: stap 4, afbeelding 1 van 2 Disassembling Nokia E61i Microphone, Front Cover: stap 4, afbeelding 2 van 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Microphone: stap 5, afbeelding 1 van 1
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Microphone, Display: stap 6, afbeelding 1 van 2 Disassembling Nokia E61i Microphone, Display: stap 6, afbeelding 2 van 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Disassembling Nokia E61i Microphone: stap 7, afbeelding 1 van 2 Disassembling Nokia E61i Microphone: stap 7, afbeelding 2 van 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Disassembling Nokia E61i Microphone, Motherboard: stap 8, afbeelding 1 van 3 Disassembling Nokia E61i Microphone, Motherboard: stap 8, afbeelding 2 van 3 Disassembling Nokia E61i Microphone, Motherboard: stap 8, afbeelding 3 van 3
    • Pull the green motherboard from the back casing.
  9. Disassembling Nokia E61i Microphone, Connector Housing: stap 9, afbeelding 1 van 1
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
  10. Disassembling Nokia E61i Microphone, Disassembling Nokia E61i Microphone: stap 10, afbeelding 1 van 1
    • After the Connector Housing has been removed, there is nothing else holding the Microphone in place. Simply remove if from the housing by pulling up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher Patton
208 Reputatie
12 handleidingen geschreven
Cal Poly, Team 9-63, Walters Spring 2011 Lid van Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,304
