Ga door naar hoofdinhoud
Disassembling Nokia E61i Keyboard
Wat je nodig hebt
  1. Disassembling Nokia E61i Keyboard, Battery: stap 1, afbeelding 1 van 2 Disassembling Nokia E61i Keyboard, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Disassembling Nokia E61i Keyboard: stap 2, afbeelding 1 van 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Keyboard: stap 3, afbeelding 1 van 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Keyboard, Front Cover: stap 4, afbeelding 1 van 2 Disassembling Nokia E61i Keyboard, Front Cover: stap 4, afbeelding 2 van 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Keyboard: stap 5, afbeelding 1 van 1
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Keyboard, Keyboard: stap 6, afbeelding 1 van 1
    • Once the front cover has been removed, there is nothing holding the keyboard to the rest of the phone. Simply remove the keyboard from the cover by lifting the keyboard from its interior side.
Conclusie
Christopher Patton
208 Reputatie
12 handleidingen geschreven
Cal Poly, Team 9-63, Walters Spring 2011 Lid van Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,719
