Ga door naar hoofdinhoud
Disassembling Nokia 3395 Logic Board
Wat je nodig hebt
  1. Disassembling Nokia 3395 Logic Board, Back Case: stap 1, afbeelding 1 van 3 Disassembling Nokia 3395 Logic Board, Back Case: stap 1, afbeelding 2 van 3 Disassembling Nokia 3395 Logic Board, Back Case: stap 1, afbeelding 3 van 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
  2. Disassembling Nokia 3395 Logic Board, Battery: stap 2, afbeelding 1 van 2 Disassembling Nokia 3395 Logic Board, Battery: stap 2, afbeelding 2 van 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
  3. Disassembling Nokia 3395 Logic Board, Front Case: stap 3, afbeelding 1 van 2 Disassembling Nokia 3395 Logic Board, Front Case: stap 3, afbeelding 2 van 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
  4. Disassembling Nokia 3395 Logic Board, Screen: stap 4, afbeelding 1 van 2 Disassembling Nokia 3395 Logic Board, Screen: stap 4, afbeelding 2 van 2
    • Remove six T6 screws.
  5. Disassembling Nokia 3395 Logic Board: stap 5, afbeelding 1 van 2 Disassembling Nokia 3395 Logic Board: stap 5, afbeelding 2 van 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
  6. Disassembling Nokia 3395 Logic Board, Logic Board: stap 6, afbeelding 1 van 2 Disassembling Nokia 3395 Logic Board, Logic Board: stap 6, afbeelding 2 van 2
    • Remove logic board as shown.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nico Lee
78 Reputatie
6 handleidingen geschreven
Cal Poly, Team 30-41, Garner Spring 2010 Lid van Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 1,895
