Ga door naar hoofdinhoud
Inleiding
This guide shows you how to access the speaker of your phone, the component which produces sound.
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure your phone is turned off.
    • Make sure your phone is turned off.
  2. Press the button on the back of the phone and slide the back panel off.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Note the small metal frame that  hold the SIM card into place.
    • Note the small metal frame that hold the SIM card into place.
    • Gently pull back the tab and lift open the frame.
  4. Retrieve your SIM card.
    • Retrieve your SIM card.
  5. Separate the front cover from the main body of the phone.
    • Separate the front cover from the main body of the phone.
    • Set the front cover, as indicated, aside.
  6. Remove the screws on the phone in the order of the colors of the rainbow (Red, Orange, Yellow, Green, Blue, Purple) with a Torx T6 screwdriver.
    • Remove the screws on the phone in the order of the colors of the rainbow (Red, Orange, Yellow, Green, Blue, Purple) with a Torx T6 screwdriver.
    • Removing the screws in this order prevents any unnecessary torsion on the circuit board. Be sure to remove the screws in the order indicated.
  7. Pull the screen assembly from the base of the phone.
    • Pull the screen assembly from the base of the phone.
    • Set the base of the phone, as indicated, aside.
  8. Carefully lift the keypad portion of the screen assembly from the circuit board.
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Separate the screen from the circuit board.
    • Separate the screen from the circuit board.
    • Note the components circled in orange. These will need to be reconnected during reassembly in order for the screen to function.
    • Set the circuit board, as indicated, aside.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Gently push down on the screen to pop it off of the assembly.
    • Gently push down on the screen to pop it off of the assembly.
  11. When the screen falls out the assembly, two white tabs will fall out with it.
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
  12. Set the screen and the tabs aside.
    • Set the screen and the tabs aside.
  13. You can now access the speaker.
    • You can now access the speaker.
    • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
  14. Remove the speaker from the assembly.
    • Remove the speaker from the assembly.
Conclusie
Sterling Fuentes
61 Reputatie
8 handleidingen geschreven
Cal Poly, Team 29-64, Johann Spring 2010 Lid van Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 1,021
