Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press the button on the back of the phone and slide the back panel off.
Remove the battery by pulling it from the phone.
Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
Press the black tabs to release the front cover from the phone.
Remove the front cover from the phone.
Set the front cover, as indicated, aside.
Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
Remove the screen assembly from the phone base.
Set the screen assembly aside.
Use tweezers to remove the microphone from the phone's base.
Één andere persoon heeft deze handleiding voltooid.
