Ga door naar hoofdinhoud
Disassembling Nokia 3100b Microphone
Wat je nodig hebt
  1. Disassembling Nokia 3100b Microphone, Battery: stap 1, afbeelding 1 van 1
    • Make sure your phone is turned off.
  2. Disassembling Nokia 3100b Microphone: stap 2, afbeelding 1 van 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Disassembling Nokia 3100b Microphone, SIM Card: stap 3, afbeelding 1 van 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Disassembling Nokia 3100b Microphone: stap 4, afbeelding 1 van 1
    • Retrieve your SIM card.
  5. Disassembling Nokia 3100b Microphone, Microphone: stap 5, afbeelding 1 van 1
    • Press the black tabs to release the front cover from the phone.
  6. Disassembling Nokia 3100b Microphone: stap 6, afbeelding 1 van 1
    • Remove the front cover from the phone.
    • Set the front cover, as indicated, aside.
  7. Disassembling Nokia 3100b Microphone: stap 7, afbeelding 1 van 1
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
  8. Disassembling Nokia 3100b Microphone: stap 8, afbeelding 1 van 1
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  9. Disassembling Nokia 3100b Microphone: stap 9, afbeelding 1 van 1
    • Note the location of the microphone.
  10. Disassembling Nokia 3100b Microphone: stap 10, afbeelding 1 van 1
    • Use tweezers to remove the microphone from the phone's base.
  11. Disassembling Nokia 3100b Microphone: stap 11, afbeelding 1 van 1
    • The microphone is now removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sterling Fuentes
130 Reputatie
8 handleidingen geschreven
Cal Poly, Team 29-64, Johann Spring 2010 Lid van Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 2,082
