Ga door naar hoofdinhoud
Disassembling Nokia 2366i Main Display
Wat je nodig hebt
  1. Disassembling Nokia 2366i Main Display, Battery: stap 1, afbeelding 1 van 2 Disassembling Nokia 2366i Main Display, Battery: stap 1, afbeelding 2 van 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Main Display: stap 2, afbeelding 1 van 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Main Display: stap 3, afbeelding 1 van 3 Disassembling Nokia 2366i Main Display: stap 3, afbeelding 2 van 3 Disassembling Nokia 2366i Main Display: stap 3, afbeelding 3 van 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Main Display, Front Cover: stap 4, afbeelding 1 van 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Main Display: stap 5, afbeelding 1 van 2 Disassembling Nokia 2366i Main Display: stap 5, afbeelding 2 van 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Main Display: stap 6, afbeelding 1 van 2 Disassembling Nokia 2366i Main Display: stap 6, afbeelding 2 van 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
  7. Disassembling Nokia 2366i Main Display, Main Display: stap 7, afbeelding 1 van 2 Disassembling Nokia 2366i Main Display, Main Display: stap 7, afbeelding 2 van 2
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
  8. Disassembling Nokia 2366i Main Display: stap 8, afbeelding 1 van 2 Disassembling Nokia 2366i Main Display: stap 8, afbeelding 2 van 2
    • Using the spudger, disconnect the green display cable.
  9. Disassembling Nokia 2366i Main Display: stap 9, afbeelding 1 van 3 Disassembling Nokia 2366i Main Display: stap 9, afbeelding 2 van 3 Disassembling Nokia 2366i Main Display: stap 9, afbeelding 3 van 3
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
Conclusie
Michael Machado
334 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-14, Amido Winter 2011 Lid van Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,056
