Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This is a prerequisite to replacing any other piece. This guide involves removing most of the screws in the shell and splitting the gun along the middle seam.
Onderdelen
Geen onderdelen opgegeven.
  1. Skip this step if magazine is already removed.
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
    My priming bar is stuck how do I fix this?
    Ethan - Antwoord
  2. Use the Phillips #0 Screwdriver to remove these 9 screws.
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Pull slide back to reveal more screws. Remove these 2 screws.
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
  4. Remove the screws on the plunger cap.
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Remove the 2 screws on the slide.
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Pull the gun apart at the middle seam. Watch for any springs that might launch out.
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
    Pay attention to the orientation of the tabs on the compression tube. The tabs fit into grooves on the side of the gun. This tripped me up.
    Bob - Antwoord
Conclusie
10 andere personen hebben deze handleiding voltooid.
Asad Qureshi
553 Reputatie
3 handleidingen geschreven
Baylor, Team 8-14, Williams Fall 2014 Lid van Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Leden
6 handleidingen geschreven
Één commentaar
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 91
Altijd: 8,931
