Ga door naar hoofdinhoud
  1. Place the monitor face down on a clean, flat surface. Place the monitor face down on a clean, flat surface.
    • Place the monitor face down on a clean, flat surface.
  2. Firmly remove the back panel of the stand by pulling it up and away from the monitor. Firmly remove the back panel of the stand by pulling it up and away from the monitor.
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand. Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Firmly grasp the stand enclosure with your hand and slide it to base of stand. Firmly grasp the stand enclosure with your hand and slide it to base of stand.
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Laptop batterijen
    Batterijen voor alle grote PC-merken, met onze kwaliteitsgarantie.
    Nu winkelen
    Laptop batterijen
    Nu winkelen
  7. Lift the the stand straight up to remove it. Lift the the stand straight up to remove it.
    • Lift the the stand straight up to remove it.
  8. Place the monitor screen face up. Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off. Continue your way around the screen.
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  9. Unscrew the two 7mm screws from the bottom of the button assembly. Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur. Pull the button assembly out a few inches and unplug the colored cables.
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  10. Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor. Remove the button assembly from the monitor.
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  11. With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  12. Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure. Carefully pull the enclosure off the monitor. Carefully pull the enclosure off the monitor.
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  13. Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor. Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  14. Pull  the the metal casing off of the monitor to reveal the motherboards. Pull  the the metal casing off of the monitor to reveal the motherboards.
    • Pull the the metal casing off of the monitor to reveal the motherboards.
Conclusie
John Patterson
217 Reputatie
2 handleidingen geschreven
Cal Poly, Team 11-36, Amido Fall 2013 Lid van Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Leden
7 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 2
Afgelopen 7 Dagen: 9
Afgelopen 30 Dagen: 45
Altijd: 3,404
