Ga door naar hoofdinhoud
Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700
Wat je nodig hebt
  1. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700, Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 1, afbeelding 1 van 2 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700, Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 1, afbeelding 2 van 2
    • Unplug the USB cord from the top of the mouse.
  2. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 2, afbeelding 1 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 2, afbeelding 2 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 2, afbeelding 3 van 3
    • Power off the mouse. The power switch is located on the bottom of the mouse above the battery.
  3. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 3, afbeelding 1 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 3, afbeelding 2 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 3, afbeelding 3 van 3
    • Remove the battery as illustrated in the images.
  4. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 4, afbeelding 1 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 4, afbeelding 2 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 4, afbeelding 3 van 3
    • Peel off the four sticker pads located on the bottom of the mouse. They will be on the top, bottom and sides.
    • Stick these pads onto a clean, flat surface for safe keeping as you continue to disassemble the mouse.
    At this point it's very likely that you destroy the glides so it's probably a good idea to order some new before attempting the teardown.
    T_aus_M - Antwoord
  5. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 5, afbeelding 1 van 2 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 5, afbeelding 2 van 2
    • Locate and remove the five screws that were hidden under the sticker pads.
  6. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 6, afbeelding 1 van 2 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 6, afbeelding 2 van 2
    • Carefully pry off the top of the mouse. This will remove the housing from the circuit board.
  7. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 7, afbeelding 1 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 7, afbeelding 2 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 7, afbeelding 3 van 3
    • Gently detach the four wires from the holder of the housing.
    • View: Underneath housing
  8. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 8, afbeelding 1 van 2 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 8, afbeelding 2 van 2
    • Remove the seven screws that hold the top housing, middle housing, and side keys together.
    • If disassembling for cleaning purposes, you need only to remove the four screws near the bottom in order to remove the top cover alone.
  9. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 9, afbeelding 1 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 9, afbeelding 2 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 9, afbeelding 3 van 3
    • Press the side keys toward the bottom of the housing.
    • This will detach the keys and wires from the housing.
    u need to push the inside upward out of the slot before pushing the side keys in. ive break part of the slot by following this….
    vampirex_88killer - Antwoord
  10. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 10, afbeelding 1 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 10, afbeelding 2 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 10, afbeelding 3 van 3
    • Gently pry the lock holding both mouse buttons.
    • View: Underneath housing (still one piece)
  11. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 11, afbeelding 1 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 11, afbeelding 2 van 3 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 11, afbeelding 3 van 3
    • Gently pry away the upper part of the housing.
    • View: Housing divided into two pieces: top and middle
  12. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 12, afbeelding 1 van 1
    • Unscrew the two screws holding the part that locks the function buttons.
    • View: Underneath middle housing
  13. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 13, afbeelding 1 van 2 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 13, afbeelding 2 van 2
    • Slowly remove the plastic part you just unscrewed.
  14. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 14, afbeelding 1 van 1
    • Carefully pull each button towards you.
    • Do not misplace the small springs attached to the buttons.
  15. Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 15, afbeelding 1 van 2 Disassembling Mouse Buttons for Logitech Wireless Gaming Mouse G700: stap 15, afbeelding 2 van 2
    • Congratulations! You are now able to clean the mouse.
    • Be careful when reinstalling the screws. Due to their small size, they strip the sockets easily if overtightened.
Conclusie
34 andere personen hebben deze handleiding voltooid.
Tomasz
879 Reputatie
1 Handleiding geschreven
7 opmerkingen
Exactly what I was looking for. Guide worked perfectly. Thanks!
oscarsdg1 - Antwoord
I need the clear image of components on the main board. Could you please help me? Do you have any image of components on the main board?
Thanks
Hupaa - Antwoord
Thanks!! I got my mouse working again.
sm3333 - Antwoord
Thanks! i got my mouse working again thanks to this article.
sm3333 - Antwoord
I did open my mouse to clean but I open the wheel too. Inside are to support torqued springs that I do not know how to put them back. in this case my mouse wheel is not working properly. Can you please help me with some pictures or an advice?
Hellyworld - Antwoord
The small springs are located in the front of the mouse, left and right from the switch which is used for the middle mouse button. i would take an photo if I could. I had the same problem before but found the solution.
egal -
Tengo un mouse logitech g502 de los primeros y la verdad que estaba muy contento con él, por el tema de que trae 2 botones a cada lado y me viene bien para macros. El uso sería juegos (CSGO o BF3/4) y autocad y Catia.
Yo utilizo tableta gráfica XP-Pen Star G430S para jugar al osu y hacer anotaciones, subrayar y corregir pequeñas cosas en los apuntes que tengo en formato word y PDF , pero he empezado a dibujar con ella y va genial.
https://www.xp-pen.es/product/256.html
qian - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 140
Altijd: 49,866
