Gereedschap
Onderdelen
Geen onderdelen nodig.
  1. Switch off the mobile.
    • Switch off the mobile.
  2. Unlock the back case before open.
    • Unlock the back case before open.
  3. Remove the battery
    • Remove the battery
    • Remove the memory card
    • Remove the Sim card
  4. Remove 6 screws Tear off a part of label
    • Remove 6 screws
    • Tear off a part of label
    • Release the usb cover
  5. Open the green case part by yours fingernail from left side to the right side with the usb socket
    • Open the green case part by yours fingernail from left side to the right side with the usb socket
    • Be care of your labels
    • If you want to repair the SIM card slot legs, be sure no short circuits in 6 legs.
  6. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  7. To release the PCB for cleaning the Display the the touch screen, remove 2 PARTS by fingernail. 1. Touchscreen adapter
    • To release the PCB for cleaning the Display the the touch screen, remove 2 PARTS by fingernail.
    • 1. Touchscreen adapter
    • 2. Sticker between the touchscreen PCB & mobile PCB
    • Remove the mobile PCB much careful form top right. Be care the touchscreen circuits.
  8. You can use a cloth, USB vacuum cleaner (be careful of the components in the green case), and adhesive tape to remove all the dust. That finger pin is left by the Motorola Support Center in Hong Kong!! You can also clean the camera lens on PCB
    • You can use a cloth, USB vacuum cleaner (be careful of the components in the green case), and adhesive tape to remove all the dust.
    • That finger pin is left by the Motorola Support Center in Hong Kong!!
    • You can also clean the camera lens on PCB
  9. Remember to put all parts back and insert the touchscreen plugs slightly.
    • Remember to put all parts back and insert the touchscreen plugs slightly.
    • Put the green case back, make sure all locks is conneted
  10. You can test the mobile before screw.
    • You can test the mobile before screw.
    • After insert the memory card, SIM card and battery, switch on the phone
    • Test call in and call out, also check the speaker
    • Open the map Apps to test Wifi and GPS
    • Bluetooth file transfer
    • Camera test and save in sd card
    • Check the sd card files
    • Try to connect with PC
  11. If all works, remove the SIM card and battery. Recheck the label is it on the top of the green case Screws up all 6 screws
    • If all works, remove the SIM card and battery.
    • Recheck the label is it on the top of the green case
    • Screws up all 6 screws
    • Put back all battery and SIM card
    • Close the back case and lock it
    • Close the USB cover
    • Done
  12. If you want to explore what inside of the battery with PCB. Here is the step to follow. Remove the label Remove the black rubber
    • If you want to explore what inside of the battery with PCB. Here is the step to follow.
    • Remove the label
    • Remove the black rubber
    • Tear the battery by hand (Be patient to repeat it many time) ***do not use any metal tools to cut it out!!
    • Also you can tear PCB by hand
  13. Remove the black rubber Tear the battery by hand (Be patient to repeat it many time)
    • Remove the black rubber Tear the battery by hand (Be patient to repeat it many time)
  14. ***do not use any metal tools to cut it out!!
    • ***do not use any metal tools to cut it out!!
  15. Also you can tear PCB by hand
Conclusie
Wing Nga PANG
151 Reputatie
1 Handleiding geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 4
Altijd: 655
