Ga door naar hoofdinhoud
Disassembling Midland X-tra Talk Radio LXT118 Circuit Board
Wat je nodig hebt
  1. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: stap 1, afbeelding 1 van 2 Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Batteries: stap 1, afbeelding 2 van 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: stap 2, afbeelding 1 van 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Case: stap 3, afbeelding 1 van 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board: stap 4, afbeelding 1 van 1
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Circuit Board, Midland X-tra Talk Radio LXT118: stap 5, afbeelding 1 van 1
    • Remove the old or broken circuit board from the front case by carefully separating it from the back.
    • Clip the red and black wires at the base of the motherboard to completely separate it from the radio case. You should have 2 separate pieces.
Conclusie
To reassemble your device, follow these instructions in reverse order, from step 6 to 1.
James Tucker Dunn
371 Reputatie
6 handleidingen geschreven
Cal Poly, Team 19-43, Regan Winter 2013 Lid van Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 890
