Inleiding
Open mouse, disable features, clean, check battery mounts and continuity.
Guide to go step by step, or YouTube.
Credit to Joy L on YouTube video
Wat je nodig hebt
Video overzicht
Thin blade/knife to start removal of bottom pads, then peel off. Lay flat to ensure it goes back on during assembly.
Four T5 screws open mouse. Two short at front, two long at rear.
When removing wheel, be careful as a a spring is underneath. Pry front holding wheel to ensure it does not pop, same with back.
Clean wheel and mouse - plenty of hairs as shown. Compressed duster spray helps.
Pop off Connector shown to disable blue button if you don't like that functionality
Connectors shown at rear of mouse can be disconnected to disable the feedback mechanism.
Several small phillips pan head screws will remove the sides and rear circuit board - keep flat head phillips in place for the laser assembly on the reverse side.
If you had batteries corrode in your device, check your mounts. Ideally use a meter to see if you have continuity on the board.
