Ga door naar hoofdinhoud
Disassembling Mercedes W123 Kick Panel
Wat je nodig hebt
  1. Disassembling Mercedes W123 Kick Panel, Kick Panel: stap 1, afbeelding 1 van 1
    • Begin by gently prying out the covers for the screws on the upper edge of the kick panel.
  2. Disassembling Mercedes W123 Kick Panel: stap 2, afbeelding 1 van 1
    • Then remove these screws.
  3. Disassembling Mercedes W123 Kick Panel: stap 3, afbeelding 1 van 2 Disassembling Mercedes W123 Kick Panel: stap 3, afbeelding 2 van 2
    • Then remove any metal screws, and any plastic trim screws, at the sides of the kick panel below the dash.
  4. Disassembling Mercedes W123 Kick Panel: stap 4, afbeelding 1 van 2 Disassembling Mercedes W123 Kick Panel: stap 4, afbeelding 2 van 2
    • Now lower the panel down and rest if on the floor.
    • It can be removed full for further ease of access, depending on the job at hand.
  5. Disassembling Mercedes W123 Kick Panel: stap 5, afbeelding 1 van 3 Disassembling Mercedes W123 Kick Panel: stap 5, afbeelding 2 van 3 Disassembling Mercedes W123 Kick Panel: stap 5, afbeelding 3 van 3
    • Now you'll want to identify some of the components you are looking at so you can begin working on the one that is having issues.
    • Here are some of the ones you may find. This car is a 1985 300D; if you have an older model the items are likely a bit different.
    • Heater blower motor
    • Over-voltage protection relay
    • Air-conditioning expansion valve
Conclusie
11 andere personen hebben deze handleiding voltooid.
Nicolas Siemsen
39.010 Reputatie
79 handleidingen geschreven
Master Techs Lid van Master Techs
Community
322 Leden
2.521 handleidingen geschreven
Één opmerking
Dear Nicolas.I have one 123 300D. 1983. This days i have the follow problem.When i turn on the switch the engine heater light just lights with low brightness and the same time the diesel level goes to full.as i turn on the engine the temperature starts going up also and in few minutes time goes until full.if it is night and i turn on the head lights on high beam the engine heat light lights with the high beam light also.After 15-20 minutes time when i driving the car everything return on normal.I check the engine heaters and are ok.my battery is new.Please help me were to check and loose this problem.
Best Regards
Pavlos
melaspavlos - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 58
Altijd: 13,400
