Ga door naar hoofdinhoud
Disassembling Macintosh IIsi Floppy Drive
Wat je nodig hebt
  1. Disassembling Macintosh IIsi Floppy Drive, Top Case: stap 1, afbeelding 1 van 2 Disassembling Macintosh IIsi Floppy Drive, Top Case: stap 1, afbeelding 2 van 2
    • Start by turning the computer around, and remove this #0 Phillips Screw.
    • There may or may not be a Phillips #0 screw here, depending on whether or not the computer has ever been serviced.
  2. Disassembling Macintosh IIsi Floppy Drive: stap 2, afbeelding 1 van 3 Disassembling Macintosh IIsi Floppy Drive: stap 2, afbeelding 2 van 3 Disassembling Macintosh IIsi Floppy Drive: stap 2, afbeelding 3 van 3
    • Now lift these two clips, and slowly pivot the case up.
    • You can now seperate the top of the computer from the rest of the machine.
  3. Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: stap 3, afbeelding 1 van 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: stap 3, afbeelding 2 van 3 Disassembling Macintosh IIsi Floppy Drive, Floppy Drive: stap 3, afbeelding 3 van 3
    • The "SuperDrive" is mounted similarly to the hard drive, and positioned right next to it.
    • Push these two tabs out, and lift the drive up.
  4. Disassembling Macintosh IIsi Floppy Drive: stap 4, afbeelding 1 van 3 Disassembling Macintosh IIsi Floppy Drive: stap 4, afbeelding 2 van 3 Disassembling Macintosh IIsi Floppy Drive: stap 4, afbeelding 3 van 3
    • Flip the drive so it is on top of the power supply, and remove the "Red-Ribbon" cable.
    • 1.44MB floppy drives need a ribbon cable with a red stripe on one side. 400KB floppy drives use a ribbon cable with a yellow stripe on one side. 800KB floppy drives can use a red, or yellow striped cable.
    • This drive was manufactured by Sony in 1990.
Conclusie
Chris Green
37.197 Reputatie
49 handleidingen geschreven
Master Techs Lid van Master Techs
Community
321 Leden
1.516 handleidingen geschreven
Één opmerking
Hi there, I have IIsi Mac but the driver couldn’t read all the floppy dsks!
note: it was stored for more than 7 years.
Q. How can I clean it and what is the suitable cleaning items you recommend?
thanks.
Abdulaziz - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 2,786
