Ga door naar hoofdinhoud
Disassembling MSI GF63
Wat je nodig hebt
  1. Disassembling MSI GF63, MSI GF63: stap 1, afbeelding 1 van 3 Disassembling MSI GF63, MSI GF63: stap 1, afbeelding 2 van 3 Disassembling MSI GF63, MSI GF63: stap 1, afbeelding 3 van 3
    • To get started with disassembling your MSI GF63, you need to flip that baby upside down and remove the 12 Philips Head screws. Note that if you just bought the laptop one of the screw might be covered by a sticker that says "Factory Seal", you may remove this sticker it will not void your warranty.
  2. Disassembling MSI GF63, Interior view: stap 2, afbeelding 1 van 1
    • Now you will see something like this then that means your right on track which leads me to believe that you carefully removed the plastic clips when removing the bottom cover
    • This laptop might not be the most aesthetically pleasing but it’s functional which is really important in this case because that means it’s basically modular you can upgrade the RAM and storage: Upgrading the NVMe or adding a additional HDD or SSD. Note that MSI GF63 has RAM which can be upgraded up to 64GB.
    • Ensure to disconnect the battery before by wiggling the white connector on the right below the cooling fan, to avoid short circuiting components
  3. Disassembling MSI GF63, Storage: stap 3, afbeelding 1 van 1
    • So when it comes to storage the MSI features a M.2 NVMe drive that is pre-partitioned with MSI’s recovery tools and Windows installation. These might seem useless considering they take up about 15~20GB but this is basically a modified version of Windows that is used when you reset your laptop in Windows settings.
    • And a SATA port for a additional 2.5” drive (This should be self explanatory it’s just for more storage).
    • If you bought this laptop brand new you might have noticed that weird looking thingy with some screws alongside the user manual, well that ‘thingy’ is actually a mounting brackets for a 2.5” drive. This is what we will use to Install a additional drive and remember as long as nothing breaks your laptop should still be covered under warranty.
  4. Disassembling MSI GF63, Memory: stap 4, afbeelding 1 van 1
    • This section is where you can upgrade your memory it uses DDR4 memory and it’s upgradable up to 64GB. This will be plenty for heavy memory intensive tasks and won’t even use up like ~50% of it.
    • It is recommended to use 3200 MHz memory, from the same manufacturer for the best performance.
  5. Disassembling MSI GF63, Cooling: stap 5, afbeelding 1 van 1
    • This part of the disassembly is the part that you really don’t want to tamper with unless you know what you are doing! This part will definitely void your warranty because a lot can go wrong with this part underneath the copper cooling pipes is your CPU and your dedicated GPU, these are basically the brains of your laptop.
    • They control the computational stuff that makes the laptop work as it should and are in charge of your graphics so these need to be cooled down
    • The least you can do here is redo the thermal paste and blow out the fans that’s it!! Note these only apply if you know what you are doing.
Conclusie
Note: Do not forget to plug the battery back into place. To reattach the back cover align the mic and headphone jacks and slide it into place.
9 andere personen hebben deze handleiding voltooid.
Jay-Jay
351 Reputatie
1 Handleiding geschreven
5Gids Commentaar
It is common for disassembly guides to end with "To reassemble your device, follow these instructions in reverse order." However, it's usually easier to take something apart than put it back together.
To snap the bottom cover back into place, you must start by aligning it with the audio jacks. Otherwise it won't fit into place.
If you are doing an upgrade, it is a good idea to disconnect the battery. This requires a lot of awkward wiggling of the connector. Before putting the bottom cover into place, do not forget to plug the battery back in.
Gary F - Antwoord Deel
This is something I actually should have mentioned in the guide, thank you.
Jay-Jay - Deel
возможно ли снять клавиши для их чистки, без снятия задней крышки?
Влад Белоусов - Antwoord Deel
(I translated your question using Google translate), No you cannot remove the keys to clean, the keys are riveted using plastic into the chassis, so you would need to drill them out, which is NOT worth it.
Jay-Jay - Antwoord Deel
come si può sostituire la tastiera per favore??
Flavio Fraier - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 165
Afgelopen 30 dagen: 558
Altijd: 13,169
