Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Deze stap is niet vertaald. Help het te vertalen
    Hold the mouse so that the bottom is facing up.
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Deze stap is niet vertaald. Help het te vertalen
    Place the mouse so that the bottom is resting against a hard surface. Lift the top cover of the mouse gently, and remove it.
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Deze stap is niet vertaald. Help het te vertalen
    Locate the scroll wheel on the mouse. Grab the scroll wheel with your thumb and index finger. Gently lift up, to remove the scroll wheel from the mouse.
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Deze stap is niet vertaald. Help het te vertalen
    Locate the spring on the scroll wheel, and carefully remove the spring. Locate the spring on the scroll wheel, and carefully remove the spring.
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Deze stap is niet vertaald. Help het te vertalen
    Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Deze stap is niet vertaald. Help het te vertalen
    Use the images to locate where the resistance spring is. This spring will easily fall off. Grab the scroll wheel and its mount and gently pull them apart.
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
Eindstreep
13 andere personen hebben deze handleiding voltooid.
Maximilian Betkowski
229 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-14, Forte Winter 2013 Lid van Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Leden
7 handleidingen geschreven
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - Antwoord
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - Antwoord
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - Antwoord
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - Antwoord
the resistence spring falled off on mine how do i out it back on help
Tay Carr - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 5,606
