Ga door naar hoofdinhoud
Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections
Wat je nodig hebt
  1. Disassembling LeapPad Explorer Tablet Interior Soldered Wire Connections, Interior Soldered Wire Connections: stap 1, afbeelding 1 van 1
    • The back panel (pictured left) has a black wire (end of wire circled red). The wire solders to the bottom right corner of the card drive.
    • The front panel (pictured right) has a black and red wire (end of wired circled green). This wire solders to a small circular spot next to where the black wire connects to the back (from above).
Conclusie
ewkpates
133 Reputatie
1 Handleiding geschreven
2 opmerkingen
To open the leappad top start with, remove battery covers and the 6 screws.
The two halves slide, bottom half towards cartridge slot, to make it harder they have used double sided tape on the bottom platic tounges, so a scredriver in the bottom will be needed to prize the slide.
Lawrence - Antwoord
Good stuff. I'm trying to slide the back plate upward, but to no avail. You mentioned tape. Where exactly is it located?
John - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 5,975
