Ga door naar hoofdinhoud
Disassembling LG VX8300 Body
Wat je nodig hebt
  1. Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: stap 1, afbeelding 1 van 3 Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: stap 1, afbeelding 2 van 3 Disassembling LG VX8300 Body, Disassembling LG VX8300 Body: stap 1, afbeelding 3 van 3
    • Power off the device by holding down the red button labeled PWR.
    • Be sure that the phone is powered off before touching the battery to avoid danger.
    • Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
  2. Disassembling LG VX8300 Body: stap 2, afbeelding 1 van 2 Disassembling LG VX8300 Body: stap 2, afbeelding 2 van 2
    • Place your finger into the semicircle gap on top of the battery.
    • Apply force downward and out, so the battery pops out of the phone.
  3. Disassembling LG VX8300 Body: stap 3, afbeelding 1 van 3 Disassembling LG VX8300 Body: stap 3, afbeelding 2 van 3 Disassembling LG VX8300 Body: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Locate the two rubber pads covering the screws at the top of the phone near the hinge.
    • Use tweezers to lift and remove the rubber pads.
  4. Disassembling LG VX8300 Body: stap 4, afbeelding 1 van 2 Disassembling LG VX8300 Body: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove all four 3mm screws from the back of the phone.
  5. Disassembling LG VX8300 Body: stap 5, afbeelding 1 van 2 Disassembling LG VX8300 Body: stap 5, afbeelding 2 van 2
    • Use your fingers to gently separate the front plate from the phone. You may need to slide a plastic opening tool along the crevice between the faces to separate it more easily.
    • Remove the casing after it has been detached. The logic board is now fully accessible.
    • Once the body case is removed, the volume and camera buttons move freely. Ensure all loose pieces remain accounted for.
Conclusie
nvalm
448 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 3-7, Duarte Spring 2015 Lid van UMass Dartmouth, Team 3-7, Duarte Spring 2015
UMASSD-DUARTE-S15S3G7
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 644
