Ga door naar hoofdinhoud
Disassembling LG 440G Rear casing
Wat je nodig hebt
  1. Disassembling LG 440G Rear casing, Turn off phone.: stap 1, afbeelding 1 van 1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. Disassembling LG 440G Rear casing, Flip phone.: stap 2, afbeelding 1 van 1
    • Flip the phone over.
  3. Disassembling LG 440G Rear casing, Rear cover removal.: stap 3, afbeelding 1 van 1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. Disassembling LG 440G Rear casing, Removal of battery.: stap 4, afbeelding 1 van 1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. Disassembling LG 440G Rear casing, Unscrew six screws along edges of casing: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. Disassembling LG 440G Rear casing, Lift casing cover: stap 6, afbeelding 1 van 2 Disassembling LG 440G Rear casing, Lift casing cover: stap 6, afbeelding 2 van 2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
Conclusie
Emily Class
107 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-1, Buehl Winter 2015 Lid van Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 Leden
8 handleidingen geschreven
Één opmerking
this would be most probably, the same guide to tear down the LG B470
douglas flores - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,682
