Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Turn off camera by moving the highlighted switch to the O-Position.
    • Turn off camera by moving the highlighted switch to the O-Position.
  2. To open the cover of the battery slot, push the highlighted tab in the direction of the arrow next to it, and gently lift. To open the cover of the battery slot, push the highlighted tab in the direction of the arrow next to it, and gently lift.
    • To open the cover of the battery slot, push the highlighted tab in the direction of the arrow next to it, and gently lift.
  3. Use your plastic opening tool to slowly pry the battery from the camera case. With your fingers, remove the battery and replace with new one.
    • Use your plastic opening tool to slowly pry the battery from the camera case.
    • With your fingers, remove the battery and replace with new one.
    • Gently close the cover of the battery slot.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
David Cottrell
58 Reputatie
5 handleidingen geschreven
UW Stout, Team 1-2, Zhou Fall 2011 Lid van UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,070
