Ga door naar hoofdinhoud
Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly
Wat je nodig hebt
  1. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly: stap 1, afbeelding 1 van 2 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly: stap 1, afbeelding 2 van 2
    • Before doing anything, ensure that the mixer is not plugged in! Then, remove the cover from the high speed attachment. If you don't have this cover, then the low speed attachments will not work anyway, as the cover engages the clutch when it is latched on.
  2. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly: stap 2, afbeelding 1 van 2 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly: stap 2, afbeelding 2 van 2
    • Now, remove the kenwood chef logo covering the front grinder attachment by pulling the white handled lever towards the edge of the mixer and then pulling the Kenwood panel away from the mixer.
  3. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly: stap 3, afbeelding 1 van 3 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly: stap 3, afbeelding 2 van 3 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly: stap 3, afbeelding 3 van 3
    • Next, unscrew the three screws holding the high-speed attachment port in place. Once removed, the attachment port lifts up freely.
    • Then, take the plastic cover off the other attachment port on the top of the mixer.
  4. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove the gearbox cover: stap 4, afbeelding 1 van 3 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove the gearbox cover: stap 4, afbeelding 2 van 3 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove the gearbox cover: stap 4, afbeelding 3 van 3
    • Now, lift the gearbox cover up and towards the front of the mixer - it should slide straight off
    • Marvel at the decades of ingredients stored safely inside your mixer!
  5. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove the drive belt and springed gear: stap 5, afbeelding 1 van 3 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove the drive belt and springed gear: stap 5, afbeelding 2 van 3 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove the drive belt and springed gear: stap 5, afbeelding 3 van 3
    • You can remove the belt that drives the gearbox at this point - if this has worn out then only the high speed attachment will have been working. It will lift off nicely with a screwdriver.
    • The large gear then needs to be gripped, and the "dog" on top of it needs to be removed.
    • You'll need to keep the gear in place - either fit an attachment and wedge a piece of timber between it and the body of the machine or get someone else to hold onto it tight) and turn the dog with a spanner. Eventually you or the person holding will feel it release, and you can unscrew the final turn carefully so the spring doesn't fly off!
    • If using timber for the above a piece of dressed timber about 120 mm long (and 15 mm wide x 10 mm high) was used succesfully for this. It can be used to refit the dog by wedging it on the opposite side when refitting
    • Apologies for the cake/belt continuity errors in this set - some are taken during reassembly
    Hey Josh
    Is there a pin or something between the lid and the dog? I can't get the %#*@ thing to engage!
    Rebecca Coleman - Antwoord
    Rebecca - the liquidiser outlet cover has a pin which should push down on the clutch dog to make it engage. If the clutch dog has worn prongs or a stripped thread it may need to be replaced.
    Benjamin Daniel - Antwoord
  6. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove/Service the Gearbox - Part 1/3: stap 6, afbeelding 1 van 2 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove/Service the Gearbox - Part 1/3: stap 6, afbeelding 2 van 2
    • If you just need to remove the large gear, here's the time to do it. You can lift it off with a pair of pliers underneath. Note that this is attached to a plastic gear inside the gearbox and this is the usual failure point if your low speed attachment is not working but your mixer runs.
    • Next, undo the screws holding the gearbox onto the mixer body. There is one on either side of the mixer (only one shown). If your motor is dead, you may not need to do this.
    I'm trying to reassemble my gearbox after regreasing, but can't get the clutch dog back on..any advice? I have the same type as in this picture, not the nylon large pulley. I'm pressing down on the dog while turning the beater fixing, but it just won't catch the threads. Is there another technique?
    Jennifer - Antwoord
    Silly question, I know, but are you turning it the correct direction? From the pics it does look like a normal RH thread.
    Adrienne Walker -
    On my a701a there are 4 machine screwss holding the gearbox on to the body. 2 at the top with nuts and 2 lower down without nuts. The lower ones only have to be loosened, as (on mine) the gerabox lifts off them.
    The large gear/drive dog assembly is different. Holding the gear does not enable removal of the dog, one has to lock the gearbox some other way
    David Walker - Antwoord
  7. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove/Service The Gearbox Part 2/3: stap 7, afbeelding 1 van 3 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove/Service The Gearbox Part 2/3: stap 7, afbeelding 2 van 3 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove/Service The Gearbox Part 2/3: stap 7, afbeelding 3 van 3
    • Next, remove the plastic cover on the bottom of the gearbox. At this point, old crumbs will be getting everywhere. This is held on by four screws, which are removed in the first picture. At this point, you also need to pull the plastic cover off the lever at the front of the mixer.
    • You now have access to the lower plastic cover - best to give this a wash along with the felt. (picture 2)
    • Behold the beauty of the Kenwood gearbox (picture 3). Best not to wash this, but remove the 6 screws to gain access.
    Hi Josh Watson, if you come back to this at some point, I would like to know how to pull apart the planetary head - the chrome plate and the big gear visible on the other side - as mine is notchy.
    Its an old machine I bought to pull apart, and it runs very noisily. The grease was black and thickened around the main gear teeth, and had spun off the teeth leaving them bare. As a result all teeth are worn. It has an aluminium sacrificial gear, not sure if they went to plastic later? Might have prevented some of the wear.
    Cheers
    Adrienne Walker - Antwoord
    Heya, I'm planning on adding a full disassembly for this as ours is currently burnt out and I think needing new brushes. I'll try and find out then.
    Josh Watson - Antwoord
    Thanks Josh. I think it should be done early on when the gearbox is still mounted, I found a copy of the service manual via someone's comment somewhere, have to find it again, and they mention Special Tools...but I think you can put something in the front outlet to lock it and undo the nut.
    Oh hey, here is the service manual and parts list.
    http://www.britishexplorers.com/Kenwood%...
    Thanks Adrienne - thats really useful! Wish I had that when I put these steps together
    Josh Watson -
    Hej! I am right now tryxing to repair an old 701A, but as a total newbie I got stuck at this stage: Gearbox still fixed, clutch dog and parts that belong to it still sitting on top.
    I´d appreciate it if someone could help me out with how the next steps look like. My aim is to open the gear and get rid of the old grease, but I have now idea how I could get the dog to move, or seperate the top cover assembly and body assembly (patrs 98, 103) Thanks in advance! @joshwatson
    d a - Antwoord
  8. Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove/Service The Gearbox Part 3/3: stap 8, afbeelding 1 van 2 Disassembling Kenwood Chef A701A Gearbox and Orbital Mixer assembly, Remove/Service The Gearbox Part 3/3: stap 8, afbeelding 2 van 2
    • One thing to do with that - open it up! The cover lifts off showing the still well lubricated gears. Normal failure point ringed - remove this and replace with a new one to fix!
    • Reassembly is the reverse of dismantling the mixer.
    We have one of these old beauties and will never part with it. My only question is, if I take the mixer apart and find I need a part or two, where do I get them from? We live near Gosford NSW. Any ideas will be greatly appreciated. Thank you.
    Steve Toomer - Antwoord
    Try someone like this although they are in Vic
    https://elliselectricals.com.au/product-...
    Adrienne Walker -
    Excellent guide.  Only omission.  The dog on top of the gear. Is it lift off  or screwed, if so is it anti clock to unscrew
    Dhanji - Antwoord
    Is the dog on top of the large gear, screwed? If so, does it come out anti clock or clock?
    Dhanji - Antwoord
    These instructions are also applicable (near enough) to the KM331 model.
    Andy Davis - Antwoord
    Thanks for sharing!Just in case the repair grease is not available locally (nationally), here’s a good alternative:
    > Super Lube 71150 Synthetic Grease PTFE Extreme Pressure High Temperature
    It is food safe (NSF H1 registered), hast the same NLGI viscosity rating as the original Shell grease (NLGI grade 2), doesn’t brake down over time and is reasonably priced. Works perfectly fine in my A701A.
    Flippo Froehlich - Antwoord
    Hi Josh,
    If there is a dodgy gearbox bearing, do you need pullers of some kind to remove it?
    removing the dog: virtually impossible by following these instructions. sorry !
    Royston Wareham - Antwoord
    You really have to go for it to remove the dog if i recall correctly. Official service manual is linked in a comment a couple of steps above and recommends a specialist tool - the steps there may be better, but I didn't have that when I did this. Let me know if that helps and I can update. Cheers
    Josh Watson -
    In my case the shaft holding the dough attachment sheared off while mixing a rye dough that was too dry in hindsight. Instructions to remove and replace this would extend the help if possible.
    woodo woodo - Antwoord
    The part that fell out on mine while kneading dough is the planetary shaft. A piece of a plastic gear subsequently fell out too. Some further instructions to get access to the insides would be helpful. Nothing seems to move at this point.
Conclusie
26 andere personen hebben deze handleiding voltooid.
Josh Watson
1.869 Reputatie
3 handleidingen geschreven
22 opmerkingen
Hi I get a slight screeching noise between speed Two and three do you think this is anything to worry about.
The mixer seems perfect at maximum speed.
D MORRIS.
David Morris - Antwoord
Hi,
I’m not entirely sure, but it sounds like the gearbox (or another part of the drive) may need greasing? The grease can dry up over time and it would lead to that.
Thanks,
Josh
what kind of oil do you use in the gearbox
Mark Corkum - Antwoord
What type of grease is used in the gearbox (my earlier question was an error)
I’m not sure on the exact spec for the grease, but make sure you get Food Grade grease - it isn’t a sealed unit. Googling Kenwood Food Grade grease finds a few sellers - I can’t remember what I used exactly but it was definitely food grade grease, not kenwood specific though.
Josh Watson -
Kenwood’s service manual specifies to use 133gr (4 3/4ozs) of Shell L.G.P.1 62814 or Shell L.G.P.1 62819. I was not able to find the specs for this grease. As the separation between the gear box and the food is properly solved I think the use o food grade grease is not mandatory, but I would recommend it anyway. Search for e.g. ‘Food Grade White Lithium EP Grease’. Kenwood Swiss no longer services those machines but the front-desk girl recommended to use just Vaseline - I really doubt about this…
I collected many links to instructionas and spare parts in a youtube playlist: https://www.youtube.com/playlist?list=PL...
There is a variety of kits available that contain grease and other spare parts you might need to repair your Kenwood. It might be a good idea to replace at the same time brushes, resistors and capacitors of the motor.
The service manual recommends to press the grease after reassemly into the gearbox one youtube guy just used a scraper to fill the box before assembly.
Walter Schütz -
Walter, Thanks for adding the service manual spec.
I’d definitely make sure to use food grade grease as the gearbox seal isn’t necessarily perfect. The gearbox on my machine above is full of cake crumbs from over the decades. Also, If you use the anything too viscous it will find its way into the mixing bowl.
Josh Watson -
Our Kenwood just came to a halt! I have dismantled as you suggest and it appears that the gearbox is OK but the orbital crank pinion has lost a couple of teeth.
It seems to turn ok now but will it do permanent damage if I do not get another pinion?
Peter Cameron
Peter Cameron - Antwoord
Hi, I have absolutely no power or noise from my A701. I’ve checked the plug fuse. Any ideas?
Timothy Wright - Antwoord
Hi, mine has done the same - it might be the bushes? I don’t know for sure; we replaced ours. However; it’s up the loft, so if lockdown carries on for much longer, expect a bush replacement guide :)
Josh Watson -
my planet hub model a701a does not turn when loaded under heavy bread stirring conditions. the drive shaft turns as both low speeds (upper and front) work correctly but the spin loosens the planet nut. the actual problem is the inside f the planet hub hole has been worn larger so that the hub does not engage the flat of the shaft. any ideas where one could get a replacement hub or complete assembly, thanks. enjoyed the vid.
donna.verner - Antwoord
Mine was working great - turned it off to add water and then refused to turn back on again. Could it be the motor?
vmonsta - Antwoord
My Kenwood Chef Classic fell off counter but carried on mixing. Cover is slightly scew and beaters dont touch bottom of bowl. Is this easy to fix? Still works.No funny sounds.
dennii.dorning - Antwoord
Hi, I’m not sure which model I have, but she has a dark blue top. My dough was very stiff, and she now makes a bad noise, kind of ticking. Dough hook still spins. Which part do u think I broke? And how do I work out which model she is please?
Breadmaker - Antwoord
Hi
I have an kenwood A701A vintage mixer, it is still working but has an electrical burning smell, any ideas what might be wrong
it probably needs a service does anyone do this? For this kenwood mixer
Lorna ketner - Antwoord
It is food safe (NSF H1 registered), has the same NLGI viscosity rating as the original Shell grease (NLGI grade 2), doesn’t brake down over time and is reasonably priced. Works perfectly fine in my A701A.
This was an excellent summary of the steps involved. I have now re-greased the gearbox and it is a lot quieter. Could I suggest one change to the steps involved? It concerns step 5; Removing the dog nut with a spanner. The suggestion is to get another person to hold the K-Beater attachment part still whilst unscrewing the dog nut. This I found impossible due to the gearing which makes it impossible to hold the K-beater attachment part still!! I found using a piece of dressed timber about 120 mm long (and 15 mm wide x 10 mm high) and placing it between the K-beater attachment part and the frame of the machine, easily allowed the dog nut to be undone. Replacement was simply putting the timber the other side to enable tightening up. (Not over tight mind). Great set of instructions. Thankyou.
John Heydon - Antwoord
Thanks for that tip John - I’ve added it to the guide!
Josh Watson -
Thank you so much for this.
Good day. My kenwood chef A701A. When working with mixer my machine works only if I open it. When I push mixer down into the bowl it does not work. Open and lift it works again. Down dead. 🤦🏼‍♀️
AïDA Stowik - Antwoord
Blender won’t turn. Mixer works fine. Motor is fine.
Kw a701a
Diana - Antwoord
Great guide but the fitting on my gear in step 5 (the dog in the guide) is different. It seems to be a cross piece with some kind of white glue holding it in place. Has anyone else come across this please and if so have they found a way to remove and replace it. Many thanks.
Ian Clay - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 61
Afgelopen 30 dagen: 311
Altijd: 37,323
