Ga door naar hoofdinhoud
Disassembling KDDI Kyocera A5521K Logic Board
Wat je nodig hebt
  1. Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: stap 1, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: stap 1, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: stap 1, afbeelding 3 van 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Logic Board: stap 2, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Logic Board: stap 2, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Logic Board: stap 2, afbeelding 3 van 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: stap 3, afbeelding 1 van 2 Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: stap 3, afbeelding 2 van 2
    • Remove the four screws with the Y0 screwdriver.
  4. Disassembling KDDI Kyocera A5521K Logic Board: stap 4, afbeelding 1 van 2 Disassembling KDDI Kyocera A5521K Logic Board: stap 4, afbeelding 2 van 2
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Logic Board: stap 5, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Logic Board: stap 5, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Logic Board: stap 5, afbeelding 3 van 3
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
  6. Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: stap 6, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: stap 6, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: stap 6, afbeelding 3 van 3
    • Rotate the phone approximately 45 degrees to the right.
    • Gently pry up the SD card slot with a spudger.
  7. Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: stap 7, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: stap 7, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: stap 7, afbeelding 3 van 3
    • Lift up on the first connection shown using a pair of pliers.
    • Disconnect the first connection between the logic board and the wire using the pair of pliers.
  8. Disassembling KDDI Kyocera A5521K Logic Board: stap 8, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Logic Board: stap 8, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Logic Board: stap 8, afbeelding 3 van 3
    • Repeat the above steps for the second connection.
    • Use the pliers to pry up the connection.
    • Use the pliers to disconnect the connection between the logic board and the wire.
  9. Disassembling KDDI Kyocera A5521K Logic Board: stap 9, afbeelding 1 van 1
    • Lift up on the bottom of the logic board with a spudger.
    • Gently remove the rest of the logic board from the phone.
  10. Disassembling KDDI Kyocera A5521K Logic Board: stap 10, afbeelding 1 van 2 Disassembling KDDI Kyocera A5521K Logic Board: stap 10, afbeelding 2 van 2
    • The logic board should now be completely disconnected from the phone.
Conclusie
Dominic Grisafe
157 Reputatie
10 handleidingen geschreven
Cal Poly, Team 28-25, Regan Spring 2010 Lid van Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,775
