Ga door naar hoofdinhoud
Disassembling KDDI Kyocera A5521K Faceplate
Wat je nodig hebt
  1. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: stap 1, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: stap 1, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Battery: stap 1, afbeelding 3 van 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Faceplate: stap 2, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Faceplate: stap 2, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Faceplate: stap 2, afbeelding 3 van 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: stap 3, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: stap 3, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Faceplate, Disassembling KDDI Kyocera A5521K Faceplate: stap 3, afbeelding 3 van 3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  4. Disassembling KDDI Kyocera A5521K Faceplate: stap 4, afbeelding 1 van 1
    • Remove the screws using a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Faceplate: stap 5, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Faceplate: stap 5, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Faceplate: stap 5, afbeelding 3 van 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  6. Disassembling KDDI Kyocera A5521K Faceplate: stap 6, afbeelding 1 van 1
    • Use the Y0 screwdriver to remove the screws.
  7. Disassembling KDDI Kyocera A5521K Faceplate: stap 7, afbeelding 1 van 2 Disassembling KDDI Kyocera A5521K Faceplate: stap 7, afbeelding 2 van 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  8. Disassembling KDDI Kyocera A5521K Faceplate: stap 8, afbeelding 1 van 3 Disassembling KDDI Kyocera A5521K Faceplate: stap 8, afbeelding 2 van 3 Disassembling KDDI Kyocera A5521K Faceplate: stap 8, afbeelding 3 van 3
    • Separate the faceplate from the phone.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dominic Grisafe
157 Reputatie
10 handleidingen geschreven
Cal Poly, Team 28-25, Regan Spring 2010 Lid van Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,698
