Ga door naar hoofdinhoud
Fix Your Stuff
Right to Repair
Parts & Tools
Inleiding
These instructions will demonstrate how to remove the camera from the KDDI Kyocera A5521K.
  1. Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone. Beneath the covers are screws. Beneath the covers are screws.
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  2. Remove the screws using a Y0 screwdriver.
    • Remove the screws using a Y0 screwdriver.
  3. Use the iPod pry tool to remove the outer screen. Two screws are now visible. Be careful not to crack the screen upon removal.  It is adhered strongly to the phone.
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  4. Use the Y0 screwdriver to remove the screws.
    • Use the Y0 screwdriver to remove the screws.
  5. Use the iPod pry tool to loosen the faceplate from the phone. Slide the pry tool along the entire crease of the faceplate to completely detach it.
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  6. Separate the faceplate from the phone. Separate the faceplate from the phone. Separate the faceplate from the phone.
    • Separate the faceplate from the phone.
  7. Firmly grab the flexible circuit with tweezers to detach (or use your fingers if you can manage a firm grip). Firmly grab the flexible circuit with tweezers to detach (or use your fingers if you can manage a firm grip).
    • Firmly grab the flexible circuit with tweezers to detach (or use your fingers if you can manage a firm grip).
  8. Carefully pry up the camera unit with a spudger. Be careful not to damage the camera unit. The camera should now be separated from the phone.
    • Carefully pry up the camera unit with a spudger.
    • Be careful not to damage the camera unit.
    • The camera should now be separated from the phone.
Conclusie
Dominic Grisafe
157 Reputatie
10 handleidingen geschreven
Cal Poly, Team 28-25, Regan Spring 2010 Lid van Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Leden
20 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,420
