Ga door naar hoofdinhoud
Disassembling Insignia NS-B2110 Bottom Panel
Wat je nodig hebt
  1. Disassembling Insignia NS-B2110 Bottom Panel, Battery: stap 1, afbeelding 1 van 2 Disassembling Insignia NS-B2110 Bottom Panel, Battery: stap 1, afbeelding 2 van 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Disassembling Insignia NS-B2110 Bottom Panel: stap 2, afbeelding 1 van 2 Disassembling Insignia NS-B2110 Bottom Panel: stap 2, afbeelding 2 van 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Disassembling Insignia NS-B2110 Bottom Panel, Bottom Panel: stap 3, afbeelding 1 van 1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Disassembling Insignia NS-B2110 Bottom Panel: stap 4, afbeelding 1 van 2 Disassembling Insignia NS-B2110 Bottom Panel: stap 4, afbeelding 2 van 2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Disassembling Insignia NS-B2110 Bottom Panel: stap 5, afbeelding 1 van 3 Disassembling Insignia NS-B2110 Bottom Panel: stap 5, afbeelding 2 van 3 Disassembling Insignia NS-B2110 Bottom Panel: stap 5, afbeelding 3 van 3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
Conclusie
Nikki
104 Reputatie
1 Handleiding geschreven
Cal Poly, Team 4-31, Amido Fall 2013 Lid van Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 8
Altijd: 220
