Ga door naar hoofdinhoud
Disassembling InFocus LP435Z External Shell
Wat je nodig hebt
  1. Disassembling InFocus LP435Z External Shell, External Shell: stap 1, afbeelding 1 van 2 Disassembling InFocus LP435Z External Shell, External Shell: stap 1, afbeelding 2 van 2
    • Place the projector on its back (buttons down) with the lens facing away from you.
    • Remove the two 84mm screws in the upper left and right corners of the projector using the Phillips #2 screwdriver.
    • Remove the remaining three 8.5mm screws using the Phillips #1 screwdriver.
  2. Disassembling InFocus LP435Z External Shell: stap 2, afbeelding 1 van 2 Disassembling InFocus LP435Z External Shell: stap 2, afbeelding 2 van 2
    • Use the plastic opening tools to push down the clips holding the lamp cover in place, and remove it.
    • There is no lamp assembly in the projector used in this guide, yours may appear different.
  3. Disassembling InFocus LP435Z External Shell: stap 3, afbeelding 1 van 2 Disassembling InFocus LP435Z External Shell: stap 3, afbeelding 2 van 2
    • Remove the two 8.5mm rear screws holding the rear case plate to the projector using the Phillips #1 screwdriver.
    • Pull the rear plate straight off and set it aside.
  4. Disassembling InFocus LP435Z External Shell: stap 4, afbeelding 1 van 3 Disassembling InFocus LP435Z External Shell: stap 4, afbeelding 2 van 3 Disassembling InFocus LP435Z External Shell: stap 4, afbeelding 3 van 3
    • Flip the projector over and turn around so that the lens faces you.
    • Twist the gray zoom adjustment ring clockwise and extend the lens all the way out, and then slide the zoom adjustment ring all the way towards the end of the lens as far as it will go.
    • Slide the front case plate towards the loosened zoom adjustment ring, until the top plate of the projector is freed from underneath the lip of the front case plate.
    • The front case plate will not come all the way off due to the zoom adjustment ring obstructing it. It will merely slide forward a bit.
  5. Disassembling InFocus LP435Z External Shell: stap 5, afbeelding 1 van 2 Disassembling InFocus LP435Z External Shell: stap 5, afbeelding 2 van 2
    • Lift away the top case plate and set it aside.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Kennedy
186 Reputatie
6 handleidingen geschreven
Cal Poly, Team 20-3, Maness Winter 2013 Lid van Cal Poly, Team 20-3, Maness Winter 2013
CPSU-MANESS-W13S20G3
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 11
Altijd: 1,386
