Inleiding
This guide will show you how to remove the edge cover of the IBM ThinkPad T42 to access some of the device's internal components. The disassembly of the rear cover is simple, but requires the removal of many screws so be sure to stay organized through this process!
Wat je nodig hebt
Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
Één andere persoon heeft deze handleiding voltooid.
