Wat je nodig hebt
Slide the highlighted tab to the left.
With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
Remove the highlighted screw with a Phillips #1 screwdriver.
Pull the hard drive out.
Remove the following screws from the fan retention bracket:
Single 5.6 mm screw.
Three 16.1 mm screws.
Use a flathead to turn the screw 180 degrees.
Remove the CPU by lifting it upwards.
Bijna klaar!
Conclusie
