Ga door naar hoofdinhoud
Disassembling HP Envy TouchSmart 15 Heat Sink
Wat je nodig hebt
  1. Disassembling HP Envy TouchSmart 15 Heat Sink, Battery: stap 1, afbeelding 1 van 1
    • Press the battery release tab and the battery will pop up.
  2. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 2, afbeelding 1 van 1
    • Remove the battery from the laptop, it will come out easily.
  3. Disassembling HP Envy TouchSmart 15 Heat Sink, Accessory Plate: stap 3, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink, Accessory Plate: stap 3, afbeelding 2 van 2
    • Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
  4. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 4, afbeelding 1 van 3 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 4, afbeelding 2 van 3 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 4, afbeelding 3 van 3
    • Pry the accessory plate up from the back of the laptop by applying force upwards where the screw was removed.
  5. Disassembling HP Envy TouchSmart 15 Heat Sink, Hard Drive: stap 5, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink, Hard Drive: stap 5, afbeelding 2 van 2
    • Use the plastic opening tool to pry the hard drive away from the board. Notice that there is a slit centered at the back of where the hard drive is sitting. This is where you'll insert the plastic opening tool as shown in the photo. Finally, pry with the plastic opening tool to remove the hard drive.
  6. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 6, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 6, afbeelding 2 van 2
    • Firmly grasp the connector's base as shown and pull to remove from the hard drive.
  7. Disassembling HP Envy TouchSmart 15 Heat Sink, Solid State Drive: stap 7, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink, Solid State Drive: stap 7, afbeelding 2 van 2
    • Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
    • After you have removed the screw, the Solid State Drive should lift up.
  8. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 8, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 8, afbeelding 2 van 2
    • Very carefully, remove the SSD by gently pulling away from the SSD socket.
  9. Disassembling HP Envy TouchSmart 15 Heat Sink, Back Plate: stap 9, afbeelding 1 van 3 Disassembling HP Envy TouchSmart 15 Heat Sink, Back Plate: stap 9, afbeelding 2 van 3 Disassembling HP Envy TouchSmart 15 Heat Sink, Back Plate: stap 9, afbeelding 3 van 3
    • Remove the highlighted rubber stoppers with a metal spudger as pictured. They should expose a screw that you will need to remove in a later step.
  10. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 10, afbeelding 1 van 3 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 10, afbeelding 2 van 3 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 10, afbeelding 3 van 3
    • Remove plastic cover highlighted. It should expose a screw that you will need in a later step.
  11. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 11, afbeelding 1 van 1
    • Remove all highlighted screws with PH 1 screwdriver. These screws are PM 2.0x2.5.
  12. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 12, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 12, afbeelding 2 van 2
    • Remove all highlighted screws from the battery access area. These are PM 1.5x2.0 screws
    These were very tricky for me, I ended up with one nonfunctional screw, it seemed as if the 00 was a bit too large for the screw.
    Yonatan Abrego - Antwoord
    Use the PH0 bit for this step.
    kevinbush85 - Antwoord
  13. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 13, afbeelding 1 van 1
    • Remove screws highlighted with PH1 screwdriver from accessory plate area.These are PM 2.5x3.0 screws
    • Remove screws highlighted with PH1 screwdriver from accessory plate area. These are PM 2.5x4.5 screws
  14. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 14, afbeelding 1 van 3 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 14, afbeelding 2 van 3 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 14, afbeelding 3 van 3
    • Pry open back plate area with plastic opening tool. The back plate should pry open with relative ease. If you feel some resistance at any point please refer to steps 2-5 because a screw has probably been missed.
  15. Disassembling HP Envy TouchSmart 15 Heat Sink, Fan: stap 15, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink, Fan: stap 15, afbeelding 2 van 2
    • There are 3 screws holding the fan in place. These are PM 2.5x4.5 screws
    What is the fans id number so I can replace it?
    RxMode - Antwoord
  16. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 16, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 16, afbeelding 2 van 2
    • There are 3 strips of tape. Remove them with your hand.
  17. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 17, afbeelding 1 van 1
    • Remove the fan by sliding it out and pulling it upwards. Set the fan off to the side to reveal the connector.
    What is the fan partnumber?
    Missan Eido - Antwoord
  18. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 18, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 18, afbeelding 2 van 2
    • Remove the black connector from the white insert shown at the center of the picture just below the fingers pinching the black connector.
    • The connector will come out straight up.
  19. Disassembling HP Envy TouchSmart 15 Heat Sink, Heat Sink: stap 19, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink, Heat Sink: stap 19, afbeelding 2 van 2
    • You should see eight screws. Each screw should have a corresponding number under it.
    • Unscrew each screw in with PH 1 Screw driver in numerical order. The screws will not come all the way out. Rotating the screw four to five times should make it loose enough to proceed. These are PM 2.0x11.0
  20. Disassembling HP Envy TouchSmart 15 Heat Sink: stap 20, afbeelding 1 van 2 Disassembling HP Envy TouchSmart 15 Heat Sink: stap 20, afbeelding 2 van 2
    • Grab the middle of heat sink like in picture one. Pull straight up, it should come off fairly easy. If there is some resistance go back to the previous step.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Ramon Villadonga
1.029 Reputatie
5 handleidingen geschreven
USF Tampa, Team 2-6, Sullivan Fall 2015 Lid van USF Tampa, Team 2-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G6
4 Leden
10 handleidingen geschreven
Één opmerking
These instructions worked perfectly for my HP Envy Touchsmart 15 J005EA.
I replaced with a none conductive arctic MX-4 without issue.
Mark Pearce - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 3,968
