Inleiding
In order to gain access to most of the internal components the top (or lid) of the printer must be removed. This guide is intended as a prerequisite for other installations.
Onderdelen
Geen onderdelen nodig.
  1. Open the front access panel by placing your finger in the front slot and pulling gently.
    • Open the front access panel by placing your finger in the front slot and pulling gently.
  2. Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
    • Open the protective lid that is covering the glass. Press gently against the base of the panel to remove the lid from the rest of the printer.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top. Remove the four 9mm T10 Torx screws on the top.
    • Remove the four 9mm T10 Torx screws on the top.
  5. Carefully lift the top panel off of the printer. Do not tear or damage the two cables that connect the top lid to the motherboard.
    • Carefully lift the top panel off of the printer.
    • Do not tear or damage the two cables that connect the top lid to the motherboard.
  6. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them. Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
    • Remove the two cables by gripping each one close to their connection ports on the motherboard and gently disconnecting them.
Conclusie
18 andere personen hebben deze handleiding voltooid.
Tim
166 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-35, Regan Winter 2013 Lid van Cal Poly, Team 18-35, Regan Winter 2013
CPSU-REGAN-W13S18G35
5 Leden
8 handleidingen geschreven
Één commentaar
I want fix my HP DESKJET F448o, My problem is, that the scanner arm is block.
When I turn on, the scanner arm is block, how can fix its?
mbeto0351 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 14
Afgelopen 30 Dagen: 62
Altijd: 6,933
