Ga door naar hoofdinhoud
Disassembling HP Compaq dx2000MT Hard Drive
Wat je nodig hebt
  1. Disassembling HP Compaq dx2000MT Hard Drive, Removing the HP Compaq dx2000MT Case Doors: stap 1, afbeelding 1 van 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Disassembling HP Compaq dx2000MT Hard Drive: stap 2, afbeelding 1 van 2 Disassembling HP Compaq dx2000MT Hard Drive: stap 2, afbeelding 2 van 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Disassembling HP Compaq dx2000MT Hard Drive: stap 3, afbeelding 1 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 3, afbeelding 2 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 3, afbeelding 3 van 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Disassembling HP Compaq dx2000MT Hard Drive: stap 4, afbeelding 1 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 4, afbeelding 2 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 4, afbeelding 3 van 3
    • Once again, this may take considerable force.
  5. Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: stap 5, afbeelding 1 van 3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: stap 5, afbeelding 2 van 3 Disassembling HP Compaq dx2000MT Hard Drive, Disassembling HP Compaq dx2000MT Hard Drive: stap 5, afbeelding 3 van 3
    • Remove the IDE data and power cables from the hard drive.
  6. Disassembling HP Compaq dx2000MT Hard Drive: stap 6, afbeelding 1 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 6, afbeelding 2 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 6, afbeelding 3 van 3
    • Remove the front bezel by pulling upwards and out from below the lowest air vent.
  7. Disassembling HP Compaq dx2000MT Hard Drive: stap 7, afbeelding 1 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 7, afbeelding 2 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 7, afbeelding 3 van 3
    • Remove the external drive faceplate by removing the two Torx T15 screws.
  8. Disassembling HP Compaq dx2000MT Hard Drive: stap 8, afbeelding 1 van 2 Disassembling HP Compaq dx2000MT Hard Drive: stap 8, afbeelding 2 van 2
    • Remove the following screws:
    • Front Torx T15.
    • Torx T15 mounting the hard drive cage to the optical drive bay.
  9. Disassembling HP Compaq dx2000MT Hard Drive: stap 9, afbeelding 1 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 9, afbeelding 2 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 9, afbeelding 3 van 3
    • Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
  10. Disassembling HP Compaq dx2000MT Hard Drive: stap 10, afbeelding 1 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 10, afbeelding 2 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 10, afbeelding 3 van 3
    • Remove the two Torx T15 screws holding this side of the hard drive in place.
  11. Disassembling HP Compaq dx2000MT Hard Drive: stap 11, afbeelding 1 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 11, afbeelding 2 van 3 Disassembling HP Compaq dx2000MT Hard Drive: stap 11, afbeelding 3 van 3
    • Proceed to the other side of the hard drive cage.
  12. Disassembling HP Compaq dx2000MT Hard Drive: stap 12, afbeelding 1 van 2 Disassembling HP Compaq dx2000MT Hard Drive: stap 12, afbeelding 2 van 2
    • Remove the hard drive from the hard drive cage by pulling it outward from the cage.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Eva Pong
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-16, Regan Fall 2011 Lid van Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Leden
17 handleidingen geschreven
2 opmerkingen
can i upgrade it to 500gb?
connor gouws - Antwoord
This was a bit misleading. The title of the article is “Disassembling HP Compaq dx2000MT Hard Drive.” Therefore, I expected to see someone actually disassembling a hard drive, which would have been really cool. Instead, the article shows only the removal of a hard drive from a desktop computer’s case. Perhaps the title should say “Removing HP Compaq dx2000MT Hard Drive” or at best “Disassembling HP Compaq dx2000MT Case.”
Thomas Daniel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 46
Altijd: 8,246
