Inleiding
There are no prerequisites required for this disassembly, but a spudger or similar opening tool is required to remove the panel.
Onderdelen
Geen onderdelen nodig.
  1. Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
    • Lodge the tip of the plastic opening tool into the top arc of the front panel. Apply a little force to cause the panel to detach.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Slide the blue opening tool along the seam applying force to continue detaching the side panel. Remove the button from the side panel. Remove the button from the side panel.
    • Slide the blue opening tool along the seam applying force to continue detaching the side panel.
    • Remove the button from the side panel.
Conclusie
After disassembly, the device components should look similar to that which is depicted in the cover image (top right of page).
Alexander
101 Reputatie
9 handleidingen geschreven
Clemson, Team 15-3, Benson Spring 2012 Lid van Clemson, Team 15-3, Benson Spring 2012
CLEM-BENSON-S12S15G3
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 1,013
