Inleiding
This guide walks through the general disassembly of components that are required from installment.
  1. Unscrew the two screws on the antenna unit using a torc-head screwdriver.
    • Unscrew the two screws on the antenna unit using a torc-head screwdriver.
      • The Torx-Head Screws' size is T-5, which is about 1.5mm.
    • Gently pry open the antenna unit with your fingers.
      • Be careful and try not to damage the small plastic tab.
  2. Slide out the inner casing attached to the antenna body.
    • Slide out the inner casing attached to the antenna body.
    • Remove the rotating joint connecting the antenna casing to the main device:
      • Squeeze tweezers into the shown location and compress the spring.
      • Lift out the outer casing while keeping the spring compressed.
      • watch out, as the spring loaded portion may fly out unexpectedly.
    • Using a torx-head screwdriver, unscrew the two revealed screws that connect the front and back of the device.
    • Insert the plastic opening tool into the center of the edge as shown in first picture.
    • Slide the plastic opening tool along the central gap of device, making sure that each edge is free, as shown in the second picture.
    • Detach the front display from the back panel of the device.
    • Using tweezers, gently lift the microphone from its resting position to fully separate the device into two parts.
    • Finally, remove the screw that connects the motherboard to the back casing with a 3mm head driver.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Robert
56 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-65, Johann Spring 2013 Lid van Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 Leden
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 5
Altijd: 1,072
