Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove to sticker on the back of the unit and then remove the two T5 scremws once this is done use a spudger to carefully pry off the silver cover.
Once the tool is inserted it can slide around the entire device.
Remove four small T5 torx screws.
Be gentle, the screws are easily stripped.
Lift cover off of unit.
Be careful not to lose small rubber piece on the bottom right corner.
Remove two T5 torx screws holding down logic board.
Disconnect battery.
Gently lift the logic board out of the unit
Be careful not to damage the battery connector on the top of the unit.
6 andere personen hebben deze handleiding voltooid.
