Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove metal sticker under the LCD screen with a spudger.
Remove the 4 gray screw caps with the spudger. These cover the screw heads and protect from dirt or grime.
Remove the 5 10mm screws with the #00 Phillips screwdriver. These connect the back of the outer shell to the front of the outer shell.
Open battery door. This can be done by gently depressing and sliding the battery down downward.
Use the spudger to separate outer shells.
The spudger must be inserted between the shell halves to pry the edges apart.
Slowly work around the outside to separate the halves.
Één andere persoon heeft deze handleiding voltooid.
