Inleiding
This guide will show you how to open your Buffalo DriveStation Axis 2TB external storage and remove a faulty internal hard drive. To replace it, follow the directions in reverse with a new hard drive.
Wat je nodig hebt
Remove the screw marked with a red arrow to access hidden top tab.
Use a pointy tool to press the two tabs around the USB 3 connector. These are accessible via the holes marked with orange arrows.
You can slightly lift the back edge up to help free the tabs as you press them in. It doesn't take much to release them, so don't push too hard.
With the cover removed, the hard drive should be exposed--refer to the first picture to locate it.
Use the flat blade screwdriver to gently pry out the plastic case the hard drive sits in.
The hard drive is only held in the case with rubber bumper style mounts, and will come out with a little finger pulling.
10 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Nice, easy and concise ‘how-to’. You made my task so much easier. Thank you!
Thanks..got the job done.
thank you for the blog. keep it up.
thanks.... just the job.
