Ga door naar hoofdinhoud
Disassembling Eureka 1660SP Motor Housing
Wat je nodig hebt
  1. Disassembling Eureka 1660SP Motor Housing, Motor Housing: stap 1, afbeelding 1 van 2 Disassembling Eureka 1660SP Motor Housing, Motor Housing: stap 1, afbeelding 2 van 2
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Disassembling Eureka 1660SP Motor Housing: stap 2, afbeelding 1 van 2 Disassembling Eureka 1660SP Motor Housing: stap 2, afbeelding 2 van 2
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Disassembling Eureka 1660SP Motor Housing: stap 3, afbeelding 1 van 3 Disassembling Eureka 1660SP Motor Housing: stap 3, afbeelding 2 van 3 Disassembling Eureka 1660SP Motor Housing: stap 3, afbeelding 3 van 3
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jennifer Sheils
4 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 342
