Ga door naar hoofdinhoud
Disassembling Ericsson CF 388 Phone Casing
Wat je nodig hebt
  1. Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: stap 1, afbeelding 1 van 3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: stap 1, afbeelding 2 van 3 Disassembling Ericsson CF 388 Phone Casing, Disassembling Ericsson CF 388 Battery: stap 1, afbeelding 3 van 3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Phone Casing, Phone Casing: stap 2, afbeelding 1 van 3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: stap 2, afbeelding 2 van 3 Disassembling Ericsson CF 388 Phone Casing, Phone Casing: stap 2, afbeelding 3 van 3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Phone Casing: stap 3, afbeelding 1 van 3 Disassembling Ericsson CF 388 Phone Casing: stap 3, afbeelding 2 van 3 Disassembling Ericsson CF 388 Phone Casing: stap 3, afbeelding 3 van 3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Phone Casing: stap 4, afbeelding 1 van 2 Disassembling Ericsson CF 388 Phone Casing: stap 4, afbeelding 2 van 2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
Conclusie
Niccolas Tones
60 Reputatie
9 handleidingen geschreven
Clemson, Team 1-1, Benson Spring 2012 Lid van Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,130
