Ga door naar hoofdinhoud
Disassembling Ericsson CF 388 Microphone
Wat je nodig hebt
  1. Disassembling Ericsson CF 388 Microphone, Disassembling Ericsson CF 388 Battery: stap 1, afbeelding 1 van 3 Disassembling Ericsson CF 388 Microphone, Disassembling Ericsson CF 388 Battery: stap 1, afbeelding 2 van 3 Disassembling Ericsson CF 388 Microphone, Disassembling Ericsson CF 388 Battery: stap 1, afbeelding 3 van 3
    • To remove the battery from the casing, grab the front panel and back panel with opposite hands (as shown). The back panel is the same as the battery.
    • With your index finger, push in the button on the bottom of the battery to release it.
    • Pull the battery away from the phone.
  2. Disassembling Ericsson CF 388 Microphone, Phone Casing: stap 2, afbeelding 1 van 3 Disassembling Ericsson CF 388 Microphone, Phone Casing: stap 2, afbeelding 2 van 3 Disassembling Ericsson CF 388 Microphone, Phone Casing: stap 2, afbeelding 3 van 3
    • After removing the battery, the front phone casing becomes accessible.
    • Locate the two star-shaped T6 screws on the bottom end of the rear of the phone, underneath the battery, as indicated by the red circles.
    • Remove these two screws using the Torx T6 Screwdriver.
  3. Disassembling Ericsson CF 388 Microphone: stap 3, afbeelding 1 van 3 Disassembling Ericsson CF 388 Microphone: stap 3, afbeelding 2 van 3 Disassembling Ericsson CF 388 Microphone: stap 3, afbeelding 3 van 3
    • Locate the top two U-shaped screws on the back of the phone, as shown by the red circles.
    • Remove these two screws with a SP 2.6 screw driver.
    • Note: Remove gray plastic grommets with screws.
  4. Disassembling Ericsson CF 388 Microphone: stap 4, afbeelding 1 van 2 Disassembling Ericsson CF 388 Microphone: stap 4, afbeelding 2 van 2
    • Grab opposite panels of the phone casing and carefully open and pull apart the phone, as shown in the image.
    • Note: Be careful not to damage the circuit board and components as you as open the casing.
  5. Disassembling Ericsson CF 388 Microphone, Keypad Support Skeleton: stap 5, afbeelding 1 van 2 Disassembling Ericsson CF 388 Microphone, Keypad Support Skeleton: stap 5, afbeelding 2 van 2
    • After removing the battery casing and taking apart the phone casing, the keypad is held in with a plastic skeleton structure as shown.
  6. Disassembling Ericsson CF 388 Microphone: stap 6, afbeelding 1 van 3 Disassembling Ericsson CF 388 Microphone: stap 6, afbeelding 2 van 3 Disassembling Ericsson CF 388 Microphone: stap 6, afbeelding 3 van 3
    • To remove the plastic skeleton structure, locate the tab at the top of the phone near the LCD display screen.
    • Carefully remove the skeleton by holding on the front phone casing with one hand and pull tab with your index finger while having your thumb at the bottom of the phone as shown.
  7. Disassembling Ericsson CF 388 Microphone, Microphone: stap 7, afbeelding 1 van 1
    • After removing the keypad skeleton, the microphone becomes accessible.
    • Locate the microphone at bottom of the phone, below the keypad, as indicated by the red circle.
  8. Disassembling Ericsson CF 388 Microphone: stap 8, afbeelding 1 van 3 Disassembling Ericsson CF 388 Microphone: stap 8, afbeelding 2 van 3 Disassembling Ericsson CF 388 Microphone: stap 8, afbeelding 3 van 3
    • To remove the microphone, carefully poke out the microphone through the front hole with a paper clip.
    • Slowly and carefully, push the microphone out.
    • Note: Do not push too hard as it could damage or fling the microphone. You don't want to lose it!
Conclusie
Niccolas Tones
60 Reputatie
9 handleidingen geschreven
Clemson, Team 1-1, Benson Spring 2012 Lid van Clemson, Team 1-1, Benson Spring 2012
CLEM-BENSON-S12S1G1
3 Leden
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 953
