Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Disassembling Epson PPC650 Replacing Flash
Wat je nodig hebt
  1. Disassembling Epson PPC650 Replacing Flash, Case: stap 1, afbeelding 1 van 3 Disassembling Epson PPC650 Replacing Flash, Case: stap 1, afbeelding 2 van 3 Disassembling Epson PPC650 Replacing Flash, Case: stap 1, afbeelding 3 van 3
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Disassembling Epson PPC650 Replacing Flash: stap 2, afbeelding 1 van 1
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Disassembling Epson PPC650 Replacing Flash: stap 3, afbeelding 1 van 2 Disassembling Epson PPC650 Replacing Flash: stap 3, afbeelding 2 van 2
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Disassembling Epson PPC650 Replacing Flash: stap 4, afbeelding 1 van 1
    • Remove 4 screws from the bottom of the camera
  5. Disassembling Epson PPC650 Replacing Flash: stap 5, afbeelding 1 van 3 Disassembling Epson PPC650 Replacing Flash: stap 5, afbeelding 2 van 3 Disassembling Epson PPC650 Replacing Flash: stap 5, afbeelding 3 van 3
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
  6. Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: stap 6, afbeelding 1 van 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: stap 6, afbeelding 2 van 3 Disassembling Epson PPC650 Replacing Flash, Disassembling Epson PPC650 Replacing Flash: stap 6, afbeelding 3 van 3
    • Optional: Remove two black screws from top of camera on the flash side for more working space.
  7. Disassembling Epson PPC650 Replacing Flash: stap 7, afbeelding 1 van 1
    • Remove clear rubber band holding flash in line with wiring.
    • Cut white wire, red wire, and black wire connecting flash element to circuit board by unsoldering ends
    • Connect new flash by soldering copper ends to their respective ends to new flash element.
Conclusie
Xan Danes
122 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-5, Buehl Spring 2013 Lid van Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 272
