Ga door naar hoofdinhoud
Disassembling Dell Inspiron One 2020 Back Cover
Wat je nodig hebt
  1. Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: stap 1, afbeelding 1 van 3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: stap 1, afbeelding 2 van 3 Disassembling Dell Inspiron One 2020 Back Cover, Back Cover: stap 1, afbeelding 3 van 3
    • Place the all in one computer face down on a soft, clean surface to avoid scratching the front.
    • Press the tab on the stand cover and lift up.
  2. Disassembling Dell Inspiron One 2020 Back Cover: stap 2, afbeelding 1 van 3 Disassembling Dell Inspiron One 2020 Back Cover: stap 2, afbeelding 2 van 3 Disassembling Dell Inspiron One 2020 Back Cover: stap 2, afbeelding 3 van 3
    • Remove the four phillips screws that attach the stand to the computer.
    • Tilt the stand up and out.
  3. Disassembling Dell Inspiron One 2020 Back Cover: stap 3, afbeelding 1 van 3 Disassembling Dell Inspiron One 2020 Back Cover: stap 3, afbeelding 2 van 3 Disassembling Dell Inspiron One 2020 Back Cover: stap 3, afbeelding 3 van 3
    • Starting from the optical drive, pry the back cover up with a plastic spudger.
    • The cover is held in place by fragile plastic clips. Careful to not break them.
Conclusie
28 andere personen hebben deze handleiding voltooid.
Tyler
4.968 Reputatie
16 handleidingen geschreven
TechForce Lid van TechForce
Business
2 Leden
25 handleidingen geschreven
Één opmerking
I took the back cover off because everytime i connected the power cable the blue light on the power cable would go out and in taking off the back cover i might find something obvious. I did not find anything obvious except for a plastic clip floating around by itself. this may be the cause to a short i am thinking. Any ideas?
kim - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 50
Altijd: 34,033
