Ga door naar hoofdinhoud
Disassembling Dell Inspiron Duo Front Cover
Wat je nodig hebt
  1. Disassembling Dell Inspiron Duo Front Cover, Front Cover: stap 1, afbeelding 1 van 2 Disassembling Dell Inspiron Duo Front Cover, Front Cover: stap 1, afbeelding 2 van 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
    • To remove the old battery from the laptop, first unscrew the eight screws (size M2.5x8) from the bottom with a Phillips #0 screwdriver, this will allow the removal of the keyboard and front panel.
  2. Disassembling Dell Inspiron Duo Front Cover: stap 2, afbeelding 1 van 2 Disassembling Dell Inspiron Duo Front Cover: stap 2, afbeelding 2 van 2
    • Flip the device over again and open the laptop so that you have access to the keyboard. There are hooks on the bottom of the keyboard, but gently pulling the keyboard towards the monitor will allow it to pull out easily. Be sure to unclamp the ribbon cable. Remove the three screws under the keyboard.
    • Remove the three plastic Keyboard and trackpad connectors (these are labeled with a blue circle on the second photograph).
  3. Disassembling Dell Inspiron Duo Front Cover: stap 3, afbeelding 1 van 2 Disassembling Dell Inspiron Duo Front Cover: stap 3, afbeelding 2 van 2
    • Next, remove the top cover from the device using the plastic opening tools. It snaps in on the sides, so don't worry if you hear it unsnapping; it's not breaking.
Conclusie
Amrit Multani
115 Reputatie
1 Handleiding geschreven
UW Tacoma, Team 1-1, Liner SU 2015 Lid van UW Tacoma, Team 1-1, Liner SU 2015
UWT-LINER-SU15S1G1
3 Leden
4 handleidingen geschreven
Één opmerking
Can I get a broken screen
Daniel Mwangi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 973
