Inleiding
If the built-in webcam on your Compaq Mini 110 is giving you trouble, it is possible to remove it. Follow these comprehensive steps to get rid of an unwanted webcam.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Use a Philips #0 Screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the rubber pads located on the corners of your Compaq Mini.
Remove the three screws holding the panel in place.
Unscrew the eight screws that are circled in the picture from the plastic top cover.
Remove the four screws that keep the bottom of the hinges attached to the base.
Remove the 4 screws keeping the screen on the plastic assembly.
After removing the cable from the back of the screen, detach the webcam assembly.
