Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Push both tabs inward simultaneously and slide the battery out.
Use a Philips #0 screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Push out the side tabs simultaneously and pull out the old RAM module.
Remove the rubber pads located on the corners of your Compaq Mini.
Unscrew all the corner screws. There are four total, one under each rubber pad.
Unscrew the screw for the bottom case located in the RAM compartment.
Remove the three screws in the silver tabs at the back of the keyboard.
Lift the keyboard away from the laptop.
Remove the three screws holding the panel in place.
Remove the eight screws that are from the plastic top cover.
Pry up the top plastic cover using a spudger.
These two tabs under the screen need to be pushed in with a spudger.
Remove the four screws that keep the bottom of the hinges attached to the base.
Pry off the top plastic cover of the display assembly.
The spudger may go all the way through to the screen-side of the cover. This is not a problem and won't damage anything.
Remove the 4 screws keeping the screen on the plastic assembly.
Take the screen off the metal connectors by unscrewing each side. Each side has 2 screws.
Detach the cable from the screen. It is connected under the foil flap.
Just pull the little thing out. It's not attached on it's own.
