Inleiding
If it needs replacing, here's how to find it.
Gereedschap
Geen gereedschap opgegeven.
Onderdelen
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Use a Philips #0 Screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the rubber pads located on the corners of your Compaq Mini.
Remove the three screws holding the panel in place.
Unscrew the eight screws that are circled in the picture from the plastic top cover.
Remove the four screws that keep the bottom of the hinges attached to the base.
Remove the 4 screws keeping the screen on the plastic assembly.
