Introduction
Sticky keys? Simply just want to get rid of your keyboard? Here's how.
Tools
Parts
No parts specified.
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Use a Philips #0 Screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the rubber pads located on the corners of your Compaq Mini.
4 other people completed this guide.
3 Comments
hi, steps 5 and 6 are not needed. not sure about removing RAM either. If I look on my removed keyboard, all I see are three places for screws - those located nearby battery socket.
I think steps 3,4,5,6,7 are not needed! The essential problem in removing the keyboard is not shown: how to lift the keyboard! Use the flat side or back of a screwdriver to push the metal strips shown in step 8 up (in the direction of the keyboard) to lift the keyboard. Put your fingers under the edge of the keyboard and pull gently but firmly. There is some resistance of the holding cover.
Thank you so much for the link!
Alex -
