Inleiding
Before accessing the screen itself or the built in webcam, you must remove the display assembly from the base.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Locate the battery and the battery tabs on the bottom of the Compaq Mini.
Use a Philips #0 Screwdriver to unscrew the two screws covering the memory compartment on the bottom of the laptop and remove the cover.
Remove the rubber pads located on the corners of your Compaq Mini.
Remove the three screws holding the panel in place.
Unscrew the eight screws that are circled in the picture from the plastic top cover.
Remove the four screws that keep the bottom of the hinges attached to the base.
5 andere personen hebben deze handleiding voltooid.
